Best Value for money Socket LGA 775 Cpu
5 Nov 2007
Hi im looking for the best value for money cpu to buy to put in my 11 year olds ASUS P5B Deluxe, he already has a E6600 in there and was wondering if its worth upgrading it, if so what would u recommend?
Or is it not worth upgrading
Thxs
Probably the X3320 - X3380. They're the Xeon versions of the Q9xxx series so usually go for a bit less. Compatible with any 775 mobo AFAIK.
I picked up an X3320 (Q9300) for £40 at the start of the year and it's great. Saying that a new £50 Pentium would destroy it!
Sold my last one for about £160 on ebay and then another one on the MM i struggled to get £100... Thats Q9650 BTW..
I would say a Q6600 or Q9550 would be reasonably cheap and i have just built a system for a friends daughter with a Q6600 and she loves it. I would have thought that Q8300/Q8400 would be silly cheap now though.
Thats a great board, you can look at the new Z97 as well as they take the same CPU's
