Hazro HZ30WiE V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black **CLEARANCE** @ £399.95 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiE V2 is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiE V2 performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiE V2 recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiE V2 collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiE V2, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiE V2 offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiE V2 is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- Aluminum Casing
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Connectivity: 1x DisplayPort, 1x DVI, 1x HDMI & 1x VGA
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 1yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Only £399.95 inc VAT.
ORDER NOW
_____
Hazro HZ27WiE 8-Bit 27" Glass LED Widescreen Professional Monitor - Black **CLEARANCE** @ £199.99 inc VAT
Hazro HZ27WiE has to be one of their best value for money achievements yet, it is actually manufacturered by LG which can be seen via the resemblance in stand design and monitor controls. Featuring a state of the art LG AH in plane switching IPS panel with a 2H Glass Gloss coating to really bring images to live along with great connectivity such as DVI-D, DisplayPort, HDMI. This monitor is ideal for any professional user or for someone who wishes to make their games look awesome.
Specification:-
- Panel Technology: AH In Plane Switching - 2H Gloss Coating
- Size: 27“ / 68.47 cm (WQHD)
- Aspect Ratio: 16:9
- Viewable Image: 596.73 x 335.66 mm
- Pixel Pitch: 0.2331 mm
- Luminance (typ.): 440 cd/m²
- Contrast (typ.): 1000:1 / 2000000:1 (dynamic)
- Viewing Angle: 178° horizontal / 178° vertical
- Response Time (typ.): 6 ms (grey-to-grey)
- Colors / Gamut: 16.7 million (8bit) / 100% sRGB
- Connectivity: 1 x DVI-D, 1 x DisplayPort (10 bit), 1 x HDMI, 1 x RGB (VGA)
- Power: DC 4pin 120W (24V)
- Horizontal Frequency: 31.5 - 98.7 kHz
- Frame Rate: 30 - 85 Hz
- Optimal Resolution: 2560 x 1440 Pixels @ 60 Hz
- Mounting Options: VESA 100x100 (M4 Thread) / Base removable
- Warranty: 1 Years Swap Out
Only £199.99 inc VAT.
ORDER NOW
Features:-
- Aluminum Casing
- DPMS / OFF: <2W
- 1yr Warranty
ORDER NOW
_____
Specification:-
ORDER NOW
