Guy in gym throwing 120 or 150kg +20kg bar
My lats seem okay, at least in proportion. I've been doing rack pulls from the knee to strengthen my lower back and lets too. It's always the very bottom portion I struggled with when doing pull downs, my wide grip pull downs were stronger than other variants, which I've been told is because of proportionally weak biceps.
Anyone got a good recommendation for a pullup/dipping 'station' for home gym?
Door frames in house aren't appropriate for the over-frame hanging ones!
Indeed pull ups are mainly back - if you know how to activate the muscles and use correct form.
60kg for reps, I reckon I've got close to 70kg in me. So thats 140kg pull up! :D
I'll need to start adding weight to my pull ups.. body weight is getting too easy!
guess at the start I'll be alright holding a 15-20kg dumbbell between legs but after that I'll need a dipping belt
Sorry whats that version?
I do wide grip pull ups with palm facing outwards.
I'm assuming "facing outwards" means pronated grip?
The advantage of pronated grip is less bicep activation and lat width/strength.
Supinated is more trap, bicep and thickness.
Also it's good to do pronated is the fact that climbing is more based on this grip, and is more mechanically efficient if you use your lats properly.
