help with 4 pin fans
3 Jul 2014
hi all.
so new to forums thanks :)
i have 3x120mm
(Coolink SWiF2-1201 Retail 120mm - Silent)
http://www.overclockers.co.uk/showproduct.php?prodid=FG-010-CL&groupid=701&catid=2331&subcat=4
And 2x80mm
Coolink SWiF2-80P Retail 80mm - PWM
http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-CL
With all 5 installed, it makes a bit of noise. 1 of em are on my cpu cooler.
So i wanted to buy a fan controller to noise down the 4 of em (those not on cpu)
But all i can find is fan-controllers with 3 pins.
So my question is. what are the 4th pin for?
And wich of the pins can i skip useing?
Cheers all
4 pin fans have an extra cable for PWM control
Pin 1 - Ground
Pin 2 - +12v
Pin 3 - RPM Sensor
Pin 4 - PWM Control
Depending on the physical design you can get away with using a 3 pin fan on a 4 pin header, but the fans will spin at 100% all the time, so you will need to use voltage control to slow the fan down
sorry for beeing a noob to this.
But how will i do that then ? :O
Had a quick look at the fans & by the looks of it you can run at between 7v to 12 volts
You can either use a fixed resistor (e.g. something like this http://www.overclockers.co.uk/showproduct.php?prodid=FG-031-NC )
Or you can get a variable resistor (which means you can vary the speed to taste/cooling needs) http://www.overclockers.co.uk/showproduct.php?prodid=OA-000-ZA
The above products aren't recommendations, there will be better ways of doing it on the market (e.g. a pukka fan controller) but the principal is the same
Can you hook me up with something better that is an fan controller?
got this chasis, so would be great if it could look like that :D
** Do not hotlink images **
Also i cant use these since i have 4 pins ?
i can remove 1 if needed. and then put on a 3 pin connecter?
but which one?
green blue yellow black ? :O
dont know what they means.
cant find anything on google :O
i still dont get it.
just.
can i take my 4 pin.
put it on a fan controller
and turn it down a notch
so the noise reduses.
yes or no ?
if yes wich fancontroller ?
thanks mate
just.
yes or no ?
thanks mate
Yes
Any? If you want to control via PWM you will need one that supports that, otherwise as long as the controller has room between the fan ports to let the 4th pin overhang it should be ok.
Tou can also get a cable splitter which connects to the CPU fan on the motherboard and a molex or SATA power connector and run three or four PWM fans from the motherboard controller or software.
YOUR BASKET
1 x Akasa FLEXA FP5S 5 Fan PWM Controller (AK-CBFA07-45) £5.28
1 x Akasa AK-CB002 PWM Fan Splitter Cable £3.59
Total : £11.84 (includes shipping : £2.48).
I've been tempted to get these myself, only thing that puts me off is the cable management aspect. I went for a fan controller instead just so it keep things tidy.
To clarify- 4-pin PWM fans WILL connect to a fan controller with 3-pin plugs. The connector will line up with the little tabs, the PWM contact will overhang the end of the socket- but you need a controller with open pins on its plugs.
I have a Lamptron FC6 with Akasa Viper PWM fans, and no issues. When connected in this way they effectively become 3-pin fans.
This is by design- it's not a cheat and you won't damage anything.
