- 24 Apr 2012
- Carlow, Ireland
Hi Guys,
Would the Enermax TB Silence UCTB12 be a good match for these rads? Going for a fairly silent set up.
They run at 900rpm and are claim to be only 11dBA!
The static pressure looks quite low though, 0.828 mm-H2O.
Given that I'll have a 360mm XT45 in push/pull and a 240mm ST30 in push, will they be able to cool a 3570k and a pair of R9 290s in crossfire, all with a healthy overclock?
I'm hoping that the lower static pressure will be offset by the amount of radiator space and I'm thinking push/pull on the XT45 to again help with the low static pressure.
All EK blocks if that matters and EK D5 pump.
Thanks.
Thanks.
