the £200 hazro one from tuesdays special offer
looks like i won the lottery as there's only a single patch of very mall backlight bleed and not a single dead pixel! couldn't be happier with it especially for the price
I received mine yesterday and its nearly perfect, one dead pixel but you can only see it when looking really close and a little backlight bleed from the top left cornor also there seems to be a tiny black mark under the screen no idea what it it and can only see it when on a white background![]()
which version did you guys buy? What do you think of the colour sharpness? Also any shades? Is the backlight decent or too dark or too bright?
I was asking OP how the change was to the new monitor, and my post gets deleted..?
*) the colours and sharpness seems better (IPS panel and higher pixel density i guess) there is some backlight bleed (IPS bleed as some people call it) but it's nothing major, here's a picture of it:hi! the change was a bit jarring (the screen seems bigger than just another 3 inches, but it isn't *i did measure it*) the colours and sharpness seems better (IPS panel and higher pixel density i guess) there is some backlight bleed (IPS bleed as some people call it) but it's nothing major, here's a picture of it:
http://imgur.com/a/T0WEW
photos aren't great but you have my hand for scale and i angled a window into the third picture so as you can see the glass on that model means you'll need to be mindful of light sources & angles
I just checked that picture....I hope your not using Windows XP!!!
received mine this morning was totally smashed (not OCUk fault hazro has really really bad packaging.
Took a trip to OCUK as needed some parts for the in laws pc (Lightning fried the mobo & router)
picked up my replacement a & and bloody amazing.
So far no dead pixels, no backlight bleed that I can see.
Didn't like HDMI to DVI-D wouldn't go above 1080p. swapped the HDMI cable and works fine now.
Brilliant in games.
it has the spot for a webcam but not 1 installed.
upgraded from a benQ 24" 1080
very lucky to get 0 backlight bleed! mine is unnoticeable when you're using it, but on a black screen it's visible
you guys getting 1440p through the hdmi that came with the monitor? or using dvi-d?
