- 16 May 2005
- Manchester
Yeah, many have more issues with removing than adding. If it is too high at best it will take much longer to cure, at worst it will spoilt. Most likely it will simply take a little longer to cure though. The higher humidity also encourages less good kinds of mould so you'll need to be vigilant about that and clean dodgy spots with vinegar.
If you convert a frost-free fridge you will probably need to add humidity however, at least after the initial phase of drying where the meat loses the initial liquid.
