Dell partition setup
6 May 2009
On a new dell latitude e7240 i have the following 3 partitions showing in disk management
A healthy oem partition - 39mb
Os (c) - boot, page file, crash dump, primary partition - 110.47gb
Recovery - system, active, primary partition - 8.73gb
What are the recovery and oem partitions for, how do i use them, what are tgey for and if they are not needed how do i get rid?
As its only a 128gb disk, 8.73gb may come in handy
However i dont want to have to reinstall windows as realised it comes with ni cd drive (i know i could put windows on usbstick but would need to get one)
First thing I do with a new machine is format it. Quicker than messing around
How when I have no CD drive and no drivers? Easy enough to put windows 7 on an 8gb pen drive I have but dont all the Dell drivers need installing in the correct order - system manager > chipset > network etc etc
The recovery partition generally contains a fresh image of windows when it was installed. Its so you can factory reset it without a disk by holding some key combo on start up. You can get rid of it, but if you need to reinstall, you will need to get hold of a disc or USB. It should be easy enough to download a partition tool, like minitool partition wizard, delete the partition then expand the windows partition to take up the space. It may be best to download a bootable usb tool like Gparted to do it.
There may be other ways to clean up a bit of space, check page file size and see if there is a large hibernation image.
Doesn't really matter what order you install drivers.
I typically do..
LAN
Chipset
Gfx
Audio
With a reboot after chipset, gfx
Download LAN driver beforehand, then get other drivers online.
hibernation is disabled and drive content indexing turned off as per this guide i have used with my main machine - http://www.overclock.net/t/1156654/seans-windows-7-install-optimization-guide-for-ssds-hdds
As its a laptop for my dad, instead of messing around with partition software I may just leave it as is now Otherwise I would need to put windows on a pen drive and find a large (i guess at least 128gb) pen drive / external hard drive to create an image of the current setup
I tried F8 on boot and then repair and with dell backup and recovery manager I can load a fresh dell os image. (im sure i got rid of dell backup and recovery manager but still, it seems to be in the repair options)
You can download them from the Dell website.
God knows why they dont make it easier. e.g. basic drivers > enter service tag > download.
There's about 100 drivers, most of which are probably un-needed bloat drivers like the dell audio manager and wifi managers
Easier? It's one of the easiest suppliers to grab drivers from..
Remember Windows 7/8 and especially 8.1 will auto install a lot of drivers anyway, just make sure you have LAN/Wifi covered.
Yeh, dell are probably the easiest to get drivers for. What i would create is a single download for basic drivers and full drivers based on model (and seperate too) that wouldnt be too hard
