Hi guys
I started cycling last November for my work commute (7km along inner 'city', with no hills) and have tried to do 4 days a week since then... I've lost close to 3" off my waist-line and just under 2 stone - but now I've found I'm putting on more weight! Nothing diet wise has changed and my legs are defo more toned than a few months ago, I guess I am just building muscle rather than losing fat? Anything I can do (I'm not too bothered but another half stone loss would be nice!)
I've been using Strava to monitor my progress and without it I'm pretty sure I wouldn't still be cycling!
Anyway onto my bikes and the real gaps in my knowledge... Prior to last November I hadn't ridden a bike since the age of around 17/18 (I'm nearly 34 now). I caught a deal at Halfords (my budget was quite low - £180) and figured the '6-week service' they do as part of a purchase would be a good choice and picked up the Carrera Subway hybrid. It was a good introduction or starter for me but as I've got better/fitter and more conditioned I reached the end of the use of the bike, I'm still intending on keeping it for the winter.
A month ago (or slightly less) I took advantage of another Halfords deal and picked up a road bike, I immediately noticed the difference.
But before we go any further, I do realise that Halfords is not the best place to go for bikes and I really wouldn't trust them with more advanced things - but the bike I picked up was again within my limited budget (£299) and the reviews I read online reassured me for my budget I wouldn't find much more (without risking buying a S/H stinker!)
I picked up the Carrera Virtuoso and changed the pedals to some 'normal' flats... I'm fully expecting to change the tyres before long and will go for some SPD's in due time (A520's). But onto why I've posted this here...
Firstly now I've got used to the road bike I'm noticing more about my use of it, coming from flat handlebars to the racer style I found hard. I'm getting there but still find quite a strain on my inner arms, is there something I can do with my body/seat positioning to help solve this? I've only dropped down onto the lower bars a couple of times and do not find it very easy! Again I think in time that'll come.
Next, I'm still finding the skinny tyres quite 'twitchy', especially now there has been a little rain!
I know these tyres (Kendras)the Virtuoso comes with are not good, what should I be looking at next for my road commute, I've heard gators mentioned? I have yet to experience a puncture, I have a track pump and have been keeping my tyre pressure topped up (around 80psi), tyre maximum is 110psi but no recommended pressure listed.
Although I've pretty much decided on the SPD's I should get (dual use), the A520's how do I go about choosing my shoes? I'm fairly picky when it comes to footwear and have been riding in my Nike Airmax TN's and 95's. Again budget will be quite tight.
And finally, when I bought the bike from Halfords the guy explained to me about 'cross-chaining' and how I should 'half' change on the crank to avoid this (never had to do it on my hybrid)... I'm still figuring it out but now the bikes been worn in I think my front derailer is slightly catching anyway, any tips on how to adjust this or how to avoid the cross chaining?
I realise that longer-term I need to get more budget together for my next road bike...
Thanks for any advice and opinions, noob here willing to learn from you pro's!
