- 2 Jan 2012
- UK.
http://www.extremetech.com/gaming/185896-how-to-use-your-ps4-as-a-media-streamer-without-dlna
As it stands, the PS4 doesn’t ship with DLNA streaming capability, ironically making the PS3 a better media center device. It’s certainly possible that we’ll see support for the standard patched in eventually, but how are we supposed to play our media library on the PS4 right now? Thankfully, there is a way, and it’s all thanks to the surprisingly useful web browser included with the PS4′s OS.
With a handy little application called Plex, you can stream just about any video on your computer or NAS directly to your PS4′s web browser. It only takes a few minutes to get going, so let’s jump right in.
Install Plex
First off, you need to install the Plex Media Server. Download it, install it, and then launch the executable. It’s simple enough, and it’s available on Windows, OS X, Linux, and FreeBSD (FreeNAS). That should cover just about everyone.
Configure server settings
Once the application is running, you can configure your settings as you please. Choose your server’s name, add your media folders to the Plex library, and tweak your networking options as you see fit. If you need to change the port configuration, you’ll need to toggle on the advanced mode by clicking the “Show Advanced” button in the upper right. Most people shouldn’t need to tinker too much, but the options are available.
Navigate to your server
Now, you need to navigate to your Plex library on your PS4. At this point, you have two options: Stream locally or stream over the internet. If you want to stream over your local network, you’ll need to find the private IP address of your media server, and then append the port number and the directory of the Plex web interface. Using the default settings, it should look something like this: http://192.168.1.103:32400/web. Obviously, your milage may vary depending on your network and port configuration. (To find your local IP address on Windows, hit Windows key, type cmd and press enter. Then type ipconfig and press enter. Your local IPv4 address will be the one that probably starts with 192 or 10. Mac users can do the same with the Terminal app and the command ifconfig.)
If you’d prefer to stream over the web, you can simply log into your Plex account at Plex.tv. Click the orange launch button, and you’ll be connected to your server. Of course, you’ll be beholden to any bandwidth limitations imposed by your internet connection, so be warned. If you have a data cap, you need to be very careful with the bit rates.
