** SILVERSTONE COOLERS - PRICE DROPS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Silverstone have announced some price drops on their Cooling range
A few nice little discounts here on arguably the best AIOs and NB coolers on the market!
Silverstone Tundra Series TD02 Liquid CPU Cooler @ £69.95 inc VAT
The Tundra TD02 is SilverStone’s first all-in-one liquid cooler and is a breakthrough in a market segment filled with similar-looking products. Its unique full alloy water-block is constructed with copper base and aluminum body for better durability compared to plastic-built competitions. The block also has a patented design that eliminates screws in its construction to provide excellent cooling performance and integration of mounting bracket for easy installation. The radiator has another patented design that utilizes brazing fins similar to those used in top air coolers for increased heat transfer efficiency by up to 40% over traditional radiators. With it fully assembled, factory filled and sealed, the TD02 can be used immediately with no need to refill. For those looking to finally have a unique all-in-one liquid cooler that is durable and well constructed, the TD02 is definitely it.
Features:-
- Easy installation with aluminum clips and steel back-plate
- Maintenance free, no refill required
- Dual auto adjustable 120mm PWM fans included
- Durable full alloy water-block for improved reliability
- Patented brazing fins radiator increase cooling efficiency by 40%
- Socket LGA775/115X/1366/2011/AM2/AM3/FM1/FM2
Specification:-
Water block
- Dimension 60mm (L) x 55mm (W) x 33.5mm (H)
- Material Copper base with nickel-plated aluminum unibody
Pump
- Motor speed 2500±200RPM
- Rated Voltage 12V
- Rated Current 0.28A
Fan
- Dimension 120mm (L) x 120mm (W) x 25mm (D)
- Speed: 1500~2500RPM
- Noise level: 16~33.5dBA
- Rated Voltage: 12V
- Rated Current: 0.3A
- Max airflow: 92.5CFM
- Pressure: 3.5mm/H2O
- Connector: 4 Pin PWM
Radiator
- Dimension: 278mm (L) x 124mm (W) x 45mm (H)
- Material: Aluminum
- Tube Length: 310mm
- Material: FEP
Application
- Intel Socket LGA775/115X/1366/2011
- AMD Socket AM2/AM3/FM1/FM2
- Net Weight 1501g
Was £94.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
Silverstone Tundra Series TD03 Liquid CPU Cooler @ £49.99 inc VAT
The Tundra TD03 is SilverStone’s first all-in-one liquid cooler and is a breakthrough in a market segment filled with similar-looking products. Its unique full alloy water-block is constructed with copper base and aluminum body for better durability compared to plastic-built competitions. The block also has a patented design that eliminates screws in its construction to provide excellent cooling performance and integration of mounting bracket for easy installation. The radiator has another patented design that utilizes brazing fins similar to those used in top air coolers for increased heat transfer efficiency by up to 40% over traditional radiators. With it fully assembled, factory filled and sealed, the TD03 can be used immediately with no need to refill. For those looking to finally have a unique all-in-one liquid cooler that is durable and well constructed, the TD03 is definitely it.
With the extruded aluminum mounting bracket for exceptional rigidity the TD02
Features:-
Specification:-
Water block
Pump
- Motor speed: 2500±200RPM
- Rated Current: 0.28A
Fan
- Speed 1500~2500RPM
- Noise level 16~33.5dBA
- Rated Voltage 12V
- Rated Current 0.3A
- Max airflow 92.5CFM
-Connector: 4 Pin PWM
Radiator
- Dimension 159mm (L) x 124mm (W) x 45mm (H)
Tube
- Length 310mm
- Material FEP
Application
- Net Weight: 1063g
Was £74.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Silverstone SST-NB04S Notebook Cooler - Silver @ £23.95 inc VAT
The Noble Breeze NB04 is a lightweight aluminum notebook cooler that is extremely light and portable. The sand-blasted aluminum bars not only offer improved aesthetics but also help increase heat conductivity. By utilizing a silent 200mm fan to disperse excess heat and designs based on human factor engineering to provide more comfortable user experience, the NB04 is the best choice for those requiring a portable and stylish notebook cooler.
Specification:-
- Dimensions: 356 x 44 x 295 mm (W x H x D)
- Color: Silver
- Weight: 902 g
- Fan: 200 mm (18 dB (A), 800 U / min.)
- Voltage: 5 V (external power supply is included)
- Compatibility: 15 inch wide notebook
Was £28.99 Inc. VAT
Only £23.95 inc VAT.
ORDER NOW
Silverstone SST-NB04B Notebook Cooler - Black @ £23.95 inc VAT
Specification:-
- Color: Black
- Weight: 902 g
Was £28.99 Inc. VAT
ORDER NOW
How do these compare against the Corsair AIO?
Probably relatively the same, all AIO coolers do. The only thing that will really change its performance really depends on how high you run he fans on the radiator and the type of fans used on the radiator. Mind you the FPI will play a part too but usually AIO units have low FPI radiators.
Now those prices are insanely good.
As the TD02 is basically the H105, that's a massive saving. Loving the colours and materials of these Tundra's too..
And a H80i (TD03) for £50 is a no brainer. :)
Flipping eck RJ, had 3 weetabix for brekkie eh :D
Amazing prices for top quality kit, would have bought one if the offer was around when I needed it :)
a bit of information since I have owned the TD03 for more than 2 months.
The fan is not very silent but it is quieter than the one comes with H80i. The performance of the fan is really good. The pump is a bit noisy compared to H80i.
Overall, I like the design of the clip. Cooling performance of the TD03 is not as good as H80i (about 3-5*C hotter). But the build quality is top and the colour is unique.
This cooler + Asus Sabranco + Kingston Fury White + Galaxy HOF = ??? you tell me?
Does anyone know how the TD02/03 fits into the Corsair Graphite 600TM case? I have looked at the top of the case and cannot see a way to fit the two pipes through? Likewise with the TD02 and the amount of space left if you fit it on the left-hand side fan.
I'm not sure if or when you plan to whack up the prices on these, but pleeeeeease just keep the TD03 like that for a bit longer. It's much more expensive everywhere else, your price is brilliant but I can't get it for another 2-3 weeks :(
like the silver/grey look
The grey/white is superb, but wish they'd coloured the blocks white! :(
Really considered these (aesthetic wise) but went with the Kraken as it IS the best AIO bar none - all of the others are much of a likeness ;)
Fantastic prices are making me think I *could* change, damn you Rich! :o ;)
