Just been doing a bit of googling, I can't find any corsair SP140 fans anywhere, just sp120's, anyone have any idea when the sp140s are going to be available? I cant find any info anywhere!
i got the AF Fans today, they're designed for volume cooling, it's not a high pressure radiator fan...... the AF has a very wide spread to it, about 130 degrees it's also dead silent, i only hear it over about 1100rpm
the blue LED looks great, but you have to remove excess moulding plastic off the blades with very fine ``wet and dry``, this doesn't bother me at all but take care, because the quality of the finish isn't brilliant, but as said, very quiet
i think you'll find that Phanteks are about the same..........only Noctura will stand out....just like a Rolls Royce, but they're a revolting colour so no thanks
