Looks great, how's the H105? Considering one of those, and are you keeping the blue of the graphics cards or going to change the coolers or modify the colour?
The blue and orange look good together with the black. Really classy build enjoy it!
Blue and orange! BOLD!
Nice though![]()
Thanks, it will take shape soon enough. I need to do some spraying and im look at other things to customise... Addictive stuff.
2 intakes 4 exhaust ??? Gunna get dusty
Do you think I should change the rad fans so that they're pulling air into the case?
Just wondering if you meant to put the psu in that way? On the 750D the fan should be facing towards the ground and has it's own filter for it.
But awesome build the colour scheme is going to be interesting![]()
Nah keep em pushing air through the rad and out the top - better performance and then you are not pulling all that hot air in to the case which will heat up the CPU and GPU quite a bit.
Just add dust filters to the intake fans if you have not already done so.
Dust filers won't help that much when you have negative pressure as air and dust are sucked in through the gaps in case.
I honestly see no harm in it. It should just decrease CPU temperatures as a lot of the air that will be going through the rad will be fresh from outside.
I am a bit worried about the amount of hot air those 290s will put out though. For some reason nearly every GPU manufacturer has made the retarded decision to use perpendicular fins in their heatsinks. All of the heat gets blown on your motherboard or into your case whereas with parallel fins most will get blow towards the back of your case.
Basically have an experiment with temps and fan orientation. Theory can only get us so far.
