Faulty 290 refunded. What to get?
4 Apr 2003
Manchester
After a month waiting for VTX's RMA system to no avail the kind chaps at OCUK have just refunded £300 for my reference 290
So I need a new card.
As that was the second one I returned I definately don't want another VTX and am not sure I want another 290 BUT, I do have a full cover block for a 290 reference (that I'm not sure I can be bothered with)
So assuming the the 300 refund plus the second hand EK block sale, which versions of the 290 or 780 should I be choosing between?
Thanks
How do you tell if the card is a reference design or not? So many cards nowadays have different coolers it's much harder to tell if they are using the same PCB :(
Ive got two vapor-x and thus far they are performing excellent, very happy with them and id recommend looking at them, they are truly monstrous !
Tri-X OC ordered
(and some lube and shoe horn)
+100 man points.
Since buying the vapor-x i have offers of marriage..
I may of been under the influence at the time. :o
