- 4 Jan 2013
<300/m
Industrial looking, School?
Is it even legally rentable as a living space? I don't see any radiators?
How above board is this?
Gut the place and get the entire room re boarded/plastered.
Clever reboarding and you could possibly lose the industrial looking surface mounts.
Fresh white paint will make the place look so much better.
Cover the floor with a dark coloured laminate and Im sure you could do something with the school looking cupboards in the corner.
That sounds like a little too much work! Also the room isn't that big, so don't want to lose any space.
Isn't the thing under the window a radiator?
White paint sounds good.
I'll take a wild guess it's an HMO?
White emulsion the lot as it is then go back over with Red Devil One Time Filler http://www.amazon.co.uk/Red-Devil-Onetime-Filler-1L/dp/B004PPJ3AO and another two coats of white
HMO?
Would paint like this do the job?
http://www.amazon.co.uk/Crown-Emuls...F8&qid=1405373042&sr=1-2&keywords=white+paint
Sounds like a good plan. Paint and fill holes and paint. Should brighten it up some! Is it suitable for painting the window frames etc as well?
Floor wise, I think Rroff was onto a winner with laminate (though I've spotted a nice second hand rug which might do), I'll check the prices out.
How hard is carpet to put down? (Just a thought)
