The sandybridge chips such as the 2500k, 26/700k use solder below the ihs. Intel stopped doing this with Ivybridge and then haswell too. Probably a cost cutting exercise imo.
Iirc with the q6600 I dropped temps from 82c max down to 68c max by lapping it and the TRUE cooler I was using. Chip was running at 3.8ghz.
Even water barely helps on a tim IHS, the heat is trapped under the lid.
If looking at z87/97 I'd hoesntly consider spending a little more on a 4790k, if for anything then its 4.4ghz stock turbo.
this one is only 190 quid so i cant really say no
And as no-one else has asked yet: have you been offered a 4770, or a 4770K? The difference is quite important.
Ahh yes the TRUE, Ryan was trying to remember the name of it on the pcper podcast and I was bellowing at the screen. How quickly we forget.![]()
Ok then I would base it on this:
Do you plan to go multi card any time soon?
Is your 2500K struggling with anything?
Have you budgeted out for a new motherboard also?
Have you factored in the sale of your current equipment?
If the answer is no for the first two then I'd stay put tbh.
So, I too would stick with the OCed 2500K for now and see what develops!
Sit on that £190 until something better pops up![]()
the rig is only for gaming at 1080p
Youd be as well going for the newer i7 4790k, out of the box turbo speed of 4.4ghz vs 4.0ghz on the 4770k.
