Android Sat Nav
Don
23 Oct 2013
Guildford
Chaps,
I have no need normally for a "sat-nav" type device but have a course tomorrow which is in the middle of nowhere and will need to use a sat nav.
I had a Sony Experia smart phone that had a "car mode" style app which was like a sat nav, got to from London - Bognor fine.
Have just upgraded to a Samsung Note and would like some form of sat nav for it.
My question is which one if any are the best? Don't mind spending upto £5 as I can claim it back on expenses.
Ta
Google Maps, good shout, didn't even think of that!
Excellent will check those out this evening. Thanks
I'm a fan of other nav apps but for the OP, Google Nav should do the job nicely.
I prefer Route 66 Navigate, which has a free 30 day trial at the moment. You can download maps on that via wi-fi in advance too. In my experience it's a bit more stable than Google navigation. Live traffic detection and avoidance are better than Google but the maps aren't updated as frequently.
Out of interest, don't they all use the same traffic system in the UK? The trafficmaster traffic api system is really the only game in town isn't it (aside from GMaps/Waze which is P2P traffic I guess)
I have used nav-free on the iphone as it doesnt use any data.
Its pretty good tbh.
I occasionally use it on the motorcycle only as I have a 10 yr old tomtom for the car.
No. The trafficmaster api feeds info to other providers.
The main players are:
- Tomtom - use 'floating car data' (basically P2P) from all vodaphone handsets, all iphones, and all Tomtom Live PNDs and apps to generate live traffic flow data, theoretically covering any road on their map. Also get data from Highways Agency, Traffic Scotland, TfL and a small number of local authorities. Their maps also have road speeds based on historic data split into 15 minute segments and a 7 day week.
- Google - use 'floating car data' from all Android handsets, plus traffic incidents from Waze. Road coverage limited compared to Tomtom.
- 'Here' (formerly Navteq / Nokia) - trafficmaster plus floating car data for TMC tables - which cover most of the 'Strategic road network' (i.e. mainly motorways and A roads)
- Inrix (formerly ITIS), get data from roadworks.org (which includes closure data from the Highways Agency, Traffic Scotland, plus floating car data from Google. They have a TMC table based product and an 'XD Traffic' product which has similar road coverage to Google. They are the ones that provide traffic info to local news stations and broadcast the 'RDS-TMC' feed via FM radio that a lot of in-car satnavs (and non live satnavs) use.
- Elgin - see roadworks.org. Gets their incident data from HA, TS, TfL and vast majority of local authorities. Syndicates data with Google, Inrix, Here. Gets their traffic flow data from Google.
It's all a bit incestuous really. For example the Inrix android app includes all of Elgin's incident data and uses Google maps but is unfortunately not a turn-by-turn navigation system.
Basically if Tomtom ever get their hands on the roadworks.org portal data (which they are in discussions to do) it's the end game for potential improvements. I can hardly imagine a better system. The same could be achievable if Google feed their floating car data and the roadworks.org portal data into Waze's routing system and enable traffic coverage for all roads.
Edit:
Of the above, Tomtom, Sygic (badly implemented though) and Route 66 Navigate use Tomtom data. Co-pilot uses Here data. Garmin and Navigon use the limited version of Inrix data. Google uses whatever the monopolies and mergers people can't stop them using (currently their own traffic flow data and Waze reported incidents - this is basically the Internet Explorer vs Netscape of our time).
