EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is about to release a new Full-Cover water block for TUL Corporation's (Power Color, Club3D and VTX3D) AMD Radeon R9 290(X) graphics cards with amended circuit board design R29FA.
EK-FC R9-290X SE directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and its VRM to remain stable under high overclocks. This water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality cast POM Acetal. Screw-in brass standoffs are pre-installed and allow for safe installation procedure. The cooling engine uses refined 0.6 mm wide microchannel structure to even further improve the heat transfer while not sacrificing the famous low hydraulic restriction design.
Up to four EK-FC R9-290X SE water blocks can be interconnected with EK-FC Terminal which allows for hassle-free piping job. Moreover this water block perfectly lines up with EK-FC R9-290X series water block for AMD reference design circuit board Radeon R9 290(X) graphics card thus allowing different model graphics cards to be used at the same time.
In order to simplify the search for suitable and compatible water block EK is adding newly released graphics cards and motherboard from various manufacturers to EK Cooling Configurator database and compatible graphics cards are being added to the list on daily basis.
The product will be available for purchase through EK Webshop and Partner Reseller Network by the end of July 2014. An aesthetic retention backplate will also be available.
http://www.techpowerup.com/203111/ek-readies-new-full-cover-water-block-for-radeon-r9-290x-graphics-cards.html
I thought I would put this in a thread on it's own as some people with the above non ref designs may be interested.
