- 4 Jan 2013
Thank you.
You will be climbing the walls after a few months in that room. Make sure to clear up the dirty needles first before you move in. I find it hard to believe you can not find a room in a shared house for that money. What are your neighbours like ?
You'll need to key and undercoat the surfaces before you apply gloss.
Or just key them and apply satinwood.
Make sure they're free of dust and grease after you've keyed them, - wipe with a bit of white spirit on a rag.
