** PHANTEKS ENTHOO LUXE - ULTIMATE EXPANSION AND COOLING CHASSIS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Today we are proud to announce pre order availability of the phantastic fantastic new Enthoo Luxe case from Phanteks.
The Enthoo Luxe front and top aluminium panels are sandblasted to create a textured appearance. This allows for an attractive and practical solution to reduce the appearance of fingerprints on the case. LED ambient lighting stretches all through the top and front of the case creating luminous edges
and providing a spectacular indirect light
effect.
The Luxe’s stealthy interior design only showcases the mainboard and it’s
components while isolating the bulky power supply out of sight with the included power supply cover. This removable cover not only isolates the power supply from view but also acts as a thermal shield from the rest of the case.
Phanteks Enthoo Luxe Full Tower Case - Black @ £119.99 inc VAT
Only £119.99 inc VAT.
ORDER NOW
Phanteks Enthoo Luxe Full Tower Case - White @ £119.99 inc VAT
ORDER NOW
Staying true to the Phanteks’ Enthoo line, the Luxe features a sandblasted front and top panel. Ambient lighting runs from the top to the front of the case on both sides.
Even though smaller in size, the Enthoo Luxe boost many features from the award-winning Enthoo Primo.
The Luxe comes pre-installed with a 200mm front fan and 2x PH-F140SP fans. Phanteks’ Enthoo
Luxe has an extensive watercooling capabilities that allows for four different radiator mounting
locations as well as sizes.
Styling Features:
- Clean and elegant design from the Enthoo series
- Sandblasted aluminum faceplates with matte finish
- Multi-color ambient lighting
- Stealthy interior design
Features:
- Dual removable harddrive cages
- Closed HDD panel
- Removable Drop-N-Lock SSD brackets
- Fully equiped with dustfilters (1x top, 1x front, 2x bottom)
- Removable top mesh panel for easy fan installation + dustfilter cleaning
- Clean cable management using Phanteks’ pre-installed Hoop-N-Loop cable ties + Removable PSU cover
- Ambient lighting with LED on/off switch and color control (10 colors)
- Modding friendly structure - fastened by screws instead of rivets (removable top/odd/hdd panel)
Specifications:
- Dimension: 235 mm x 560 mm x 550 mm (W x H x D)
- Form Factor: Full tower
- Material(s): Aluminum faceplates, Steel chassis
- Motherboard support :ATX, EATX, uATX, SSI EEB
- Front: I/O 2x USB 3.0, 2x USB 2.0, Mic, Headphone,
- LED: switch
- Side window: Yes, split-window design
- Expansion slots 8
- External 5.25” 3
- Internal 3.5” 6 (2x 3HDD cages)
- Internal 2.5” 8 (2x on SSD brackets)
Liquid Cooling:
- Front Up to 240
- Top Up to 360/420
- Rear 120/140
- Bottom Up to 240/140
- 5 Year Warranty
With the launch of the Enthoo Luxe, Phanteks have also released a range of accessories designed to be the perfect addition to their Enthoo range.
Phanteks Enthoo Luxe Multicolor LED Strip - 1m @ £13.99 inc VAT
Transform your Enthoo Luxe with Phanteks’ multicolor LED waterproof strips. Double sided 3M tape to keep the LED firm on your chassis and installaiton is easy with the plug and play connector. The LED strip allows the user to control the colors with the Luxe LED switch matching the Luxe’s LED with the strip. The Multi-colored LED comes in two lengths
Only £13.99 inc VAT.
ORDER NOW
Phanteks Enthoo Luxe Multicolor LED Strip - 2m @ £16.99 inc VAT
Only £16.99 inc VAT.
ORDER NOW
Phanteks Pump Mounting Kit @ £5.99 inc VAT
There are many different watercooling pumps out there and choosing one is very
diffcult. The pump bracket will be an easy upgrade with the predrilled mounting holes which is compatible with many of the water pump out on the market.
Only £5.99 inc VAT.
ORDER NOW
Phanteks PWM Fan Hub @ £12.95 inc VAT
The PWM hub (PH-PWHUB_01) provides users with the power to control and connect up to 6 fans with one single hub, delivering PWM capabilities to all fans that are connected to it. The hub is now enclosed inside a cover with a illuminated logo that lights up when powered on. If 6 fans are not enough, the retail Y-splitter can be the solution to your problem.
The Y-Splitter (PH-CB-Y3P) allows you to connect 2 fans to each fan header on the PWM hub, up to 11 fans total (requires extra PH-CB-Y3P)
Only £12.95 inc VAT.
ORDER NOW
Phanteks SSD Mounting Kit, 1x 2.5 for Enthoo Series @ £4.99 inc VAT
Upgrading storage capacity to your Enthoo cases can now be easier with the SSD
brackets. For the Luxe and the Pro, a single slot SSD bracket (PH-SDBKT_01) is available to maximize your storage and a double slot SSD bracket (PH-SDBKT_02) is available for the Enthoo Primo.
Only £4.99 inc VAT.
ORDER NOW
Phanteks SSD Mounting Kit, 2x 2.5 For Enthoo Series @ £5.99 inc VAT
Only £5.99 inc VAT.
ORDER NOW
OMG I want one in white so bad.....! I love that you have the LED strips also :D How do you control the colour of these strips?
Rough ETA?
Price on the Luxe is unbelievably good. I was expecting this to cost £150.00 Ono. @Colin, my guess is that the light strip works in tandem with the one that's already fitted to the luxe. I suspect you would need to mod the strip for it to work in the primo.
Yep, I'd like to have a red led strip in the primo. My stock one is quite fickle and refuses to work sometimes. I'm guessing its just a loose connection as it has happened before, usually after dismantling the case for cleaning etc.
Damn this is such a lovely case... with all the extra's too - well thought out!
So, any suggestions on how to justify this as a necessary purchase to the other half?
What's your case atm?
I got a CM HAF X mate, brought purely on cooling performance and not aesthetics... The Luxe is so much more my style of case (in fact all of the Phanteks cases are!) but hard to justify atm. Maybe Santa will be kind to me :D
Damn you RavenXXX2 ;) after watching that video I bought a white one, this will replace my current ever day pc which is currently housed in a CM-690 II.
Handy bit of info near the end of the video, he says the led strip accessory is only compatible with the Luxe atm.
Shame about the led strips not working with other phanteks cases. Pity this case was delayed so long, as much as i like the primo this would have been a lot more practical.
