Hazro HZ30WiE V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black **CLEARANCE** @ £389.99 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiE V2 is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiE V2 performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiE V2 recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiE V2 collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiE V2, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiE V2 offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiE V2 is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- Aluminum Casing
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Connectivity: 1x DisplayPort, 1x DVI, 1x HDMI & 1x VGA
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 1yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Only £389.99 inc VAT.
ORDER NOW
_____
Asus Xonar D2X 7.1 PCI-E Sound Card @ £69.95 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Only £69.95 inc VAT.
ORDER NOW
Features:-
- Aluminum Casing
- DPMS / OFF: <2W
- 1yr Warranty
ORDER NOW
_____
- Vista Ready
ORDER NOW
