Got an upcoming loop which I had planned to use white fluid for.
Now this stuff is the only thing I can find, which makes me suspicious that white fluid is not necessarily a good idea.
So basically I have 2 questions:
a) Is this stuff going to cause me any problems over another colour/clear?
2) Would it replace the need for biocide/silver coil when mixed with standard de-ionised water?
Loop in case it is important
EK LTX Nickel Plexi
EK FC-780 GTX Ti - Nickel
Alphacool NexXxoS ST30
XSPC AX360
Primochill PrimoFlex Advanced LRT
EK D5 Vario X-Res 140
EK Nickel Compression fittings
EK Nickel plated brass barbs
Alphacool chrome plated brass rotary barbs
XSPC AX360
