You can use voltage control but even if you set it manually in Afterburner adding +250 it limits the voltage to approx 1.367. In tri-x if I add +200v it reports 1.352. It won't do 1.4.
That's a bit disappointing.
Have you tried flashing a different bios? That should work. Try a Tri-X bios.
Don't try a Tri-X bios, the Tri-X is a reference board with custom cooler, the Vapor X is custom pcb with custom cooler, chances are it'll blow up.
