Fx 8320 @ 4.5 vs 3570k or 4670k ?
29 Dec 2012
Hi guys I just wanted to know the answer to the following
The reason I ask is I've upgraded a few bits on my main pc and have some parts laying about,
I've been looking for a cpu and motherboard to build a spare pc to keep or sell.
from the prices I've found I thought i maybe better off just getting a new cpu and motherboard for the main pc.
With the core support AMD. Without it? up to you really.
However, now that Intel have finally mustered up an 8 core CPU then that should really seal the deal.
from what ive been told, the cores dont make much difference, over all which is better.
or if you can put them in order of the top 3 with the reason why.
Just average performance? 4670k > 3570k > 8320.
Games like BF4 that use multiple cores, the 8320 could pull ahead if you clock it enough.
If your coming from an FX i would buy the i7 4790K. The i5 are good but you want serious improvement for your investment. i7 it is :D
Im not desperate for a upgrade and a i dont have loads of money,
I was just wondering if it would be worth spending some extra cash to get a 4670k, will i see a improvement ?
owould I be better off just build a spare pc as best as i can, instead of focusing on the 4670k
Unless you plan on fitting a stupid GPU arrangement the 8320 is a fine CPU.
Edit. Just stick with the 8320. Now that Intel are finally releasing an 8 core CPU into the world every one will sit up and take notice, because it's Intel.
Then your 8320 will get better support and be every bit as good as any I5.
Bits on both sides imo. In some really cpu demanding environments where core and mhz would be required a fx clocked up high could give an advantage, though in general terms the i5 would be faster per mhz and have more power per core.
Only thing i will say is going to a new platform i5 4670K is not going to be cheap. :) Oh and if buying new , get the 4690K i5
Good comments from both. If you are tight for money then not worth the hassle, stick with what you have and save the cash for later.
Thanks guys, so in general it would not be worth the upgrade yet.
The way things are heading now you could find yourself not needing a new CPU for years. The new consoles are here, dust has settled. It's GPU power and vram you will find yourself needing. If you're sensibly speccing games then the 8320 should cut it for a good while yet :)
I wouldn't be upgrading 8320 @4.5 to a I5, while the I5 would be faster at the same clock speed, it just wouldn't be worth the outlay.
Either wait out for Haswell E or save for an I7.
This +1
Hopefully we'll get games that are far more multi-threaded soon.
The new consoles don't miraculously make current and older games multi-threaded though do they?
Your missing the point. He is speccing a 'spare pc' from existing parts of which exists an FX cpu. One could argue that it's the GPU that needs all the focus, but Andy is quite right in mentioning that for some situations that hardware will more than cut it.
If you have ignored the potential of games beginning to use mantle for example - that make the rather gimped FX range play titles around the same experience as an i7 then search the forums.
Counter arguments of the "but 99% of games.." are invalid as we do not know the full library of games he plays or indeed wants to play. :o
That will always be valid....
If you like hugging the past and stroking it gently? sure.
I don't care about what has been, I care about what's coming. I don't sit here and think "Eeee, wish they'd release a CPU to run that game from 2009".
I worry more about playing the newest titles. I've got numerous old rigs I can use to play old games.
