VW polo fuse help
20 Jun 2005
Oxfordshire at the mo'
My charging unit (ciggy lighter) has stopped working, this I think maybe due to a penny found in the bottom, forums suggest a blown fuse but the fuse looks fine, has anyone any ideas? Have also tried different charging units but they are all dead in mine but work fine in other cars.
Thanks in advance
2008 match
red 10 right near bottom is the fuse for the unit
It doesn't say in the manual, there is no card in panel with fuses, and it had been working for over a year with the 10 amp, a lot are saying to use 15 amp. I have lost the fuse now anyway it fell into hole when trying to put it back, any ideas what may happen if I put a 15amp in? I know nothing much about cars, just learning.
Try this one. The one you checked is the right one, this is the only other fuse I can see that might be related though.
Thanks guys, will check it out tomorrow. Have also read there maybe a fuse behind the lighter itself will find that out when I take it pieces tomorrow. If all else fails will get a replacement unit and see if that works. Just seems funny that a penny was in it when it stopped working which suggests a blown fuse.
I would have said absolutely not. The purpose of a fuse is to be the weak point of a circuit, so if anything goes wrong, it fails. If you up the fuse rating, then maybe something else is the weak point - and maybe that weak point bursts into flames when it fails!
But:
Given that information, go for it!
Fixed it!!! was the yellow fuse, so much for the internet...
Big thank you to andy mk3 who circled it and to all others who posted replies
Those other motoring forums ain't got nothing on us! Time travelling to help people out and everything. :D
Hi there, Just reading through this thread and I have the same problem with the above.
I have looked at the red fuse and it is all good, what was the other yellow fuse that people changed that fixed the problem? :D
