ex360 vs rx360
Probably not. All my research has pointed to, that beyond physical size (240mm, 360mm etc) there is not a lot of performance difference between rads.
For those 2 I found a detailed review where the EX was put against the much larger RX. He found that a low RPM fans the performance was close whereas at higher RPMs the RX pulled ahead.
Review here (be warned it is a bit technical, especially for my WC rookie mind at 1.27am)
http://martinsliquidlab.org/2012/12/22/xspc-ex360-radiator/4/
I was contemplating the same move on 480s.
Summer weather is absolutely hammering my temps.
Running 2 x EX480s and a 4770k and 2 x 780Tis are heating the loop up fast fast fast.
