Cheers I see there's pretty much no difference
Well, if you are strictly using the rad under 600rpm then I would still say get the lowest fpi rad
the RX V3 smashes pretty much everything in this performance category. quite why someone would consider an AC rad over a V3 is beyond me.
I did the same thing for pretty much the same reason (PC noise is so irritating)
I'm running a pair of 480's HW Labs Black ICE SR-1's, with 22 Noctua fans running at 300ish RPM. It's so quiet that you can hear the HDD in my SkyHD box over the PC & only hear it when you start playing with benchmark software etc...
Wow that's crazy that they even start spinning at those rpm, what components do you have in your build and what temps are you seeing under full load?
There's a pair of 480 SR-1's, a 240 SR-1 & a 120 Black Ice GTS in the loop being driven by 2 D5 PWM pumps. It's currently cooling:
- Asus Rampage IV Extreme (NB & SB chipset)
- 3930k @ 4.6Ghz
- 64GB RAM fitted with EK Dominator blocks
- 3 x GTX Titans - mildly overclocked
At idle temperatures are between 3-4 degrees above ambient. It's currently being rebuilt at the moment though
Doesnt come with puncture guards and isnt available in 140mm sizes.
ok the guards isnt a really good reason but for some only having 120mm is a deal breaker. If they started doing the rx in 140/280/420 sizes that might help
you love xspc don't you?![]()
How do these RX's compare to the SR1's?
puncture guards are pointless when the rad comes with screws the right length.
140mm rads are a MASSIVE minority. the gulf in sales between 120 and 140 standard rads is enormous. no point catering for a tiny market.
The rx3 has a higher fpi than the v2 so at higher fan speeds id imagine it performs better
Also don't forget that the RX is a double over fin design, so while it says 13 FPI it's fin resistance/performance is actually comparable to 26 FPI for normal fins.
For decent fan speeds the RX is a no brainer, but for silent cooling SR1 all the way.
