About to play a new MMO Whos with me?
It can be confusing between presets (which have names) and souls (which also have names). Riftblade is a soul, not a preset. You can see which three souls each of the presets uses when you select them, or you can make your own out of any combination.
I'm in sunny Maidenhead for the next 3 days, should be back online Thursday night, or Friday evening depending on what time I get home.
sounds like a good idea to me i was going to give everquest 1 a try but think i'll switch to this instead if i can find a few people.
might be worth updating the first page with the details.
The first page had the details i'll look at doing it later, just add me or birgs or anyone from the list will get you updated and in Niyxi will have to add you to the guild though.
oops quite right appologies, i'm being a muppet, i was to busy reading the comments to have registered the details in your post.. cheers nuzik
You should appoligise! :D:cool:
No worries cheers will chase up Niyxi about getting you in the guild, he's currently team building with "work FWEEEEENDS"
pretty sure most people can invite people into the guild by now :)
Think I'm at 30 right now, but working the old gathering skills in too.
Mainly been on late at night and won't be on too much this coming weekend due to getting some work finished, but we need to set a guild night when we can get as many on as possible and run some guild missions.
Only a few of us at the moment, but we are online most nights and active on TeamSpeak.
I'm going to try and do a bit of recruiting when I get back tonight, as I have been working away from home for the past 3 days.
I think the aim for us is just to get ourselves in a good position for the expansion due this year (well this is my goal anyway). Once we get a few more to 50 we can do runs of the 50+ dungeons and then start the experts at 60. After that, once people have a bit more Hit we can do the first 2 raids, they only require 10 people and are quite easy.
I played it quite often when HammerKnell was the top raid and for a little bit when SL came out.
I have a L20 something toon on that server that I could join up with, DPS mage if thats OK.
I could start a new toon if needed.
