Permabanned
- 28 Dec 2009
- london
Good or bad? *WARNING RANT BELOW*
My initial impression is that it is the worse piece of software that i have ever seen. I have it installed on a 2012 r2 which is terrible in its own right. But 2013, its like they went out of their way to make everything worse. I dare touch DAG as i imagine that to be even worse than it was in 2010 and that says a lot as 2010 DAG was poorly designed to the say the least.
Moving public folders required days of work and loads of scripts and would have been impossible if it was not for some poor expert on the internet who had made a blog explaining what to do.
Then the ECP, where to begin UHH. The design is terrible, this flat white with these ugly fonts, there is no structure to it, you can't get any information that you need without going in to these ugly popup windows. The fonts, oh wait i moaned about the fonts already, but
WHY?
Then features, mailbox moves now need to be named? yea that makes sense and now with 20 extra clicks. Then we have the ECP which keeps failing with
Server Error in '/ecp' Application.
Apparently a common problem, *sigh*
Then server 2012? oh no, they didn't just make a full screen start menu on a server OS? why? Did they even test this in terminal services, did they even see how slow a full screen start menu is on terminal services before they rolled it out on a server OS? I hope they didn't test it because if they did test it and rolled it out anyway they are worse than i thought.
They took everything annoying about server 2008 and did nothing with it, they then took everything that worked and made it as annoying as they could and then they added a whole new load of annoyances.
Things that needed some work like the MSC snapins, did nothing with it, things that worked fine, server manager, they redesigned it so that it was more annoying than they could possibly make it. Did i mention the fonts? the flatness is just disgusting and yep they added an annoying action center flag to not only the server manager but the ECP. Yep, every time you do anything on the ecp you get a notification on the action center flag that you just did what you just did. Brilliant.
I only just started using it so i am sure i will fine more annoyances.
What do i like it about.... not seen any improvements yet. Maybe someone can point out what they have improved or what is now easier? i would be happy to hear it?
WHY?Then features, mailbox moves now need to be named? yea that makes sense and now with 20 extra clicks. Then we have the ECP which keeps failing with
most windows admin's seem to prefer a GUI for most day to day things and use powershell to accomplish repetitive tasks. Its just a shame the M$ are inconsistent on what they want in the GUI and what they want only in powershell.
linux has a degree of intuition about how it works, ms's love of almost spoken like commands blur the lines to much imo
