Can you buy R9 280'S with 1 fan
17 Dec 2004
Can you buy these with 1 fan, because at the moment I have a HD 6950 with a fan at the far right and my only pcie x2 slot I can use, is the next slot down from my graphics card. At the moment I can use my pcie x2 slot if needs be, but if I got a new gpu that has 2 fans on, any pcie card will partly block up the first fan on the gpu. I am not using the pcie x2 slot currently but it would be nice to keep it clear if I ever do.
The other idea is to use a riser card?
The other idea is to use a raiser card?
You mean the blower stile cards?
Like this? http://www.hisdigital.com/un/product2-801.shtml
They exist but are difficult to find.
HIS actually pulled a bunch of blower style HD7950's that Gibbo was waiting to arrive so they could re-brand them as 280's. So the must be some out there somewhere...
Ah So a 7950 is as fast as a 280? If this is true I might go down the 2nd hand route as I will be saving loads. Is the 7950 as fast as the 280X?
Yeah thats the stile cards I mean:)
