** ACER G-SYNC SHOWCASE VIDEO!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Acer has made a video to show off the technologies in their G-Sync monitors which are available from OcUK.
They have given this video exclusively to OcUK, so see it first here on our channel:-
So for those still a bit unsure what G-Sync and the other technologies actually do, this video helps show it, even if a little extreme. :D
You can buy the hardware from OcUK and we shall be getting stock first:-
Acer XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red @ £367.99 inc VAT
Acer XB270HA gaming monitor as the world’s first 1080P 27" display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB270HA is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 27-inch LED backlit display with True HD (1920 x 1080 pixels).
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB270HA features 170/160 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HA monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:-
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:-
- G-Sync Technology
- 3D Vision Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 27"
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 1920x1080 144Hz
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (144Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Only £367.99 inc VAT.
ORDER NOW
Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
Features:-
Specification:-
- G-Sync Technology
- Display Screen Size: 28" (70.8cm)
- Panel Type: TN
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Connectivity: 1x DisplayPort 1.2 (60Hz)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Only £499.99 inc VAT.
ORDER NOW
Pretty unfair posting that Gibbo. I have it pre-ordered and I am like a kid in a sweet shop who is told to wait till the 5th September before he can have some sweets :D
Gregster
Muhahahahahaahahah!
At least your one of the first and Acer are doing their best to airfreight a small amount over to us early. :)
That would be awesome if it happens and happy to be a tea boy for the day to come up and get it :D
Hey man.
Being serious now I would happily invite you up to come collect your monitor, you can have a tour of OcUK HQ and meet 8 Pack. :)
Upto you, just let me know! :)
Nice one and when you get them in, let me know and I will come up :) About time I came to see the faces behind the Avatars :)
They have done a very good job visualizing the benefits of G-Sync with this video, you could show this to people asking what it is and not need to explain further.
Yep it is superb, very happy with what they have done for us, can't see how it could be done better. :)
Agreed but I do feel they have exaggerated it a tincy wincy bit :D
Being serious yes and no, now I've seen it in action, the tech demo's show it to be as good as in that video!
In actual games it is noticeable as well, but not quite so extreme. ;)
Sorry but the video isnt exclusive to ocuk.
See. Was posted a month before you have on their own utube channel.
Still a cool vid tho.
Lol I saw. :D
BTW sry about post with link in. Didn't intend to sound like that but rereading it I see I did. I could have sounded nicer.
That video is such a crock of *****
I don't have Gsync and my games don't look like that at all, nothing that blurry, nothing that stuttery or teary. Talk about PR BS! I mean hell was it running at 10fps or something?
Cheers Gibbo for the post.
While I would like my Acer 4K to arrive early, I kinda prefer to receive it on my birthday as initially expected (5/9) :D
I think it was more about emphasising what gamers get and they done it in a way that stands out.
This video gives a fantastic description of how G-Sync works and gives a fairer descrition.
The problem is watching at 30fps and not in real life. The guys who have seen G-Sync in real life have been wowed by it.
