** ACER G-SYNC SHOWCASE VIDEO!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Acer has made a video to show off the technologies in their G-Sync monitors which are available from OcUK.
They have given this video exclusively to OcUK, so see it first here on our channel:-
So for those still a bit unsure what G-Sync and the other technologies actually do, this video helps show it, even if a little extreme. :D
You can buy the hardware from OcUK and we shall be getting stock first:-
Acer XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red @ £367.99 inc VAT
Acer XB270HA gaming monitor as the world’s first 1080P 27" display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB270HA is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 27-inch LED backlit display with True HD (1920 x 1080 pixels).
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB270HA features 170/160 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HA monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:-
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:-
- G-Sync Technology
- 3D Vision Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 27"
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 1920x1080 144Hz
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (144Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Only £367.99 inc VAT.
ORDER NOW
Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
Features:-
Specification:-
- G-Sync Technology
- Display Screen Size: 28" (70.8cm)
- Panel Type: TN
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Connectivity: 1x DisplayPort 1.2 (60Hz)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Only £499.99 inc VAT.
ORDER NOW
4K at 28 inches must look ridiculously crisp!
Yes the text is a little small for desktop usage. But for me the negatives end then, doing graphics work at 4k is sublime and movies/games look out of this world, there is little need if any for AA at such resolution. :)
The great thing is that now 4k can be smooth because of the G-sync. :)
And £500 seems extremely reasonable! Shame it is only 60Hz but I suppose that is still enough for general gaming, 120Hz would be amazing though.
Only one IPS which can do more than 60Hz, which is the Eizo with 240Hz, but no G-Sync. :)
Interested in this but my whole setup is based around AMD at the moment, will wait to see what freesync brings to the table first although that could be a while :/
Have heard a lot of rumor that FPS at 4k arent to great as things like target identifers are tiny?
:D That's what I like to hear, can't wait to see mine in action when it arrives in September!
