My girlfriend had her car MOT'd and serviced last Friday, and all it needed were two new rear pads. All was well(it drove back form the garage ok), but then on Monday, when driving it started making a horrible droning noise from the rear right wheel. The droning completely stops when pressing the brake and seems to get quieter when turning left (when compared with straight on or right).
Now, my first thought is something isn't right with the brake pad fitting as it never made any such noise before they were done on Friday. However, I have done some reading and it sounds like it could be a wheel bearing and it is just a coincidence that it started a few days after the mot/service and rear pad change.
Also, it has started to make a more high pitched squeal from the left front wheel as well but I don't know whether that is related.
Would a bad wheel bearing make a very loud drone/rumbling that could be heard very loudly in the car, and would the noise also stop completely when you step on the brakes (if it was the bearing).
Any insight would be much appreciated.
