Hi all,
Hope you're all enjoying the fantastic summer weather!
Last year, I purchased a system (see spoiler) which I didn't think I would want to upgrade. I still do not see the need to change anything however I've been looking into purchasing another 770. The one I currently have is the MSI one. I've also been looking into buying another monitor, either same as the one I currently have or the IPS version.
Having thought about this for some time, I decided to ask the community for advice.
My questions are;
1 - If I was to purchase another 770, would I 'NEED' to buy the 2GB version or would the 4GB version also 'work' in terms of having two graphics cards in my computer?
2 - If another graphics card is purchased, what sort of power supply would I be looking to get in order to support the power consumption of the two cards?
3 - Regards the monitor, what is the significant difference between IPS and the standard LED-Backlit LCD Display and which do you recommend?
4 - Another purchase point for me would be getting a closed loop CPU cooler. Would anyone be able to recommend a decent one?
I do not have a set budget so feel free to suggest what you believe is best for it's value in terms of 'speccing' hardware.
Thanks!
|| Intel 4670K || Alpenföhn Groß || NVIDIA GTX 770 || MSI Z87-G45 || Patriot Venom 2x 4GB (2400MHz) || Samsung 840 (250GB) SSD || Corsair HX 650 || BitFenix Shinobi (German Edition) ||
|| Asus VN247H || Samsung SyncMaster T190 || TT eSports Theron 5600 DPI ||
|| Qpad Mk-80 (Blue Switches) || 2013 Astro MixAmp Pro || 2013 Astro A40 ||
My questions are;
Thanks!
