I have been stripping & rebuilding an engine these last few weeks however I have managed to shear the head clean off a nut that attaches the water pump to the timing chain cover.
I am left with about 8-9 mm of the bolt protruding & was considering welding a nut onto the end of it in order to remove it but I've been told the heat will damage the aluminium, will this be the case or will I likely be ok?
Any help greatly appreciated!
