Hi all,
I'm looking at installing a 12v socket that is fed from an ignition live, rather than the original socket which is a constant live.
What's the best way to do this?
I've read that the only way to do this, without cutting into original cabling, is to get an "add a circuit" piggy back fuse and use it to replace the fuse of an 'item' that is only on when the ignition is on?
Would it then be okay to still run that original item and the 12v socket from the same feed?
Any help would be appreciated please
Thanks in advance
Thanks in advance
I'm not recommending that one is used by the way and I wouldn't use it again. The Fiesta didn't care though, when the fuse was pulled you of course get the warning light on the dash but putting it back in with the fuse tap in also was fine in the months I had it anyway.
