GTA IV - ICENHANCER 3.0 out!
Got mine downloaded, however it doesn't seemed to have either work or loaded correctly.
Will report back after I have reloaded a backup and done it again.
Use the mirrors from the main post? Mine downloaded right away using the mirror links. Works fine although it kills my FPS ha which I expected tbh.
Wow looks great I never played GTAIV its been sat in my steam library for ages might give it a go. On Facebook there are 6 different links do you need to download them all or is it an all in one download.
I like this comment
iCEnhancer .
Extra tex with decryption key. will update when i can ******g access my website...
I just downloaded EFLC one, where do I put it? This is what I've extracted:
So what do I put where, The Readme doesn't specify at all.
Done it now, great.
Looks really good, this game needs some AA though. Getting loads of staircasing at distance on things like signs above the road, which makes two lines of colour sort of flow across them until you get close.
Not sure why it would melt pcs as all i see it does is get rid of the filters gta 4 uses to dull the colours and maybe adjust the lighting a bit. Unless theres somit else im missing that actually adds performance drops for some reason.
Had a go just now. Wouldnt drop below 40fps unless u really tried with loads of action. Maxed tho without shadows due to the performance hit shadows in that game cause and without vsync. Somehow they made definition (p) not work as in switch for some reason. Also dof is a bit weird, duno if i like that tbh.
30 odd frames per second on my MSI 7950 at 1100, 1500 :0(
looks sweet though. Anyone else notice it go out of focus now and then?
Yes, I'm getting a fair bit of that. Is that depth of field? I think you can change it somehow in the mod files.
I thought it was the depth of field too but that usually takes things out of focus the further away they here. The out of focus I noticed happens to the whole scene. lasts for about a second.
is it one of these ?
+ OPTIONAL :
This release contains a file called.
**icenhancer_config.txt**
Take a look at it if you're curious.
+ To disable the DOF in-game or during cutscenes.
HOLD 1 (NOT THE NUMPAD) then HOLD PAGE DOWN.
+ To enable the DOF
HOLD 1 (NOT THE NUMPAD AGAIN) then HOLD PAGE
+ If lens distortion enabled.
HOLD 7 then USE PAGE UP / DOWN.
+ To move the DOF in MANUAL_DOF SETTINGS
HOLD 2 (NOT THE NUMPAD) then HOLD PAGE UP/DOWN.
I cant get the game to start. Using Steam version if I launch it I get the Social Rockstar club signin window. I put my credentials in click play it says I am successfully logged then window disappears and game doesnt load.
