Antec Kúhler H2O 950 Liquid CPU Cooler @ £29.99 inc VAT
The Antec KÜHLER H2O 950 provides cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. In addition to easy installation, dual powerful PWM fans pushes air through directional blades and channels it for optimal cooling.
The dual 120 mm Pulse Width Modulation (PWM) fans and extra large pump ensure quiet, efficient cooling, while the double wide radiator is equipped to cool any high performance CPU on the market. An integrated fan, pump, and radiator allows coolant to circulate through the radiator at a higher velocity which in turn increases cooling performance. Lastly, the included Antec Grid™ software helps you monitor and control the KÜHLER H2O 950 and allows you to customize its stylish RGB LED. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
Features:-
- Copper cold plate is optimized for thermal conduction
- Extra large pump and integrated fan were engineered to cool the radiator efficiently
- Two Integrated PWM fans automatically adjust fan speed based on temperature. Built-in directional blades focus airflow through the radiator
- RGB LED illuminates your case and changes color to indicate CPU temperature
- Included software provides essential tools to control and monitor the KÜHLER H2O 950
Specification:-
- Fan Speed: 600 - 2400 RPM
- Radiator Dimensions: 159mm x 120mm x 50mm
- Fan Dimensions (2 Total): 120mm x 25mm / 4.7" x 1.0"
- Cold Plate + Pump Height: 1.0" / 26 mm
- Tubing Length 11.8" / 300mm
- Cooling Liquid: Safe, Environmentally-friendly, anti-corrosive
- Weight: 1.3kg
- Warranty: 3years
Only £29.99 inc VAT.
ORDER NOW
_____
Edifier Spinnaker 2.0 Speaker System - Black @ £79.99 inc VAT
The award-winning Spinnaker by Edifier is an iconic system, standing 15 inches tall the abstract shape is designed to be visually striking as well as a facilitator to enhance the audio performance. The shape projects sound towards the listener with a 19mm silk domed, front facing tweeter, a 23/4 inch mid-range driver, reinforced with a downward firing 4 inch subwoofer in each satellite. The Spinnaker is Bluetooth enabled, allowing audio connectivity to any Bluetooth device that supports both A2DP and AVRCA profiles for versatile track navigation, play/mute and volume adjustment through the multi-functional dome-shaped remote control. The remote control operates on a 433Mhz radio frequency up to a 10M radius making all control options easily accessible without the disturbance of inanimate objects. An optical and auxiliary input port is also available for connectivity to other external multimedia devices simultaneously. A speaker-output port allows an external subwoofer/speaker to be connected for additional base performance, making the Spinnaker a versatile system for both home and office use.
Frequency response: 68Hz - 20kHz +/-3dB on reference axis
Frequency range: 50Hz - 23kHz -10dB
Crossover frequencies: 135Hz -10dB
Distortion: 0 0.5%
Input sensitivity: 800mV±50mV
Audio input: Bluetooth, Optical, Auxiliary
Audio output: Bass expansion for outboard subwoofer
Adjustment: Wireless remote control
Power supply: Input 100V-240V AC, Output 20V/60W DC
Speaker unit: Treble: 19mm silk dome, Magnetically shielded, 4ohm Midrange: 2¾ inch (70mm), Magnetically shielded, 4ohm Bass: 4 inch (116mm), Magnetically shielded, 6ohm
Dimension: 140mm x 413mm x 189mm (W x H x D)
Weight: 4.3Kg (net) | 5.3Kg (gross)
Total power output: RMS 10W x 2 +10W x 2 + 25W x 2
Only £79.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Weight: 1.3kg
- Warranty: 3years
ORDER NOW
_____
Distortion: 0 0.5%
ORDER NOW
