they disagree until enough physical evidence is obtained that points to one obvious explanation - evolution is one of those.
Which has nothing to do with ascribing a belief in it, which is what Dolph and myself are refereeing to.
No holes at all really. It's just a personal preference to me. I'm not saying I'm correct.
Evolution is a set of comparative theories that have been combined to create a methodology over a significant period of time, and it is as Dolph stars an accepted method that explains what we observe and the data we have..it is no more nor less than that.
The better scenario to illustrate this premise is if we look at Climate Science where there is significant issues with both our knowledge and the assumptions we make based on the interpretation of that limited knowledge and the data as perceived by different Authorities within the discipline itself. The same is seen in my own field of Cognitive Science, a huge disparity on theories and conclusions based on similar data is often the norm.
This goes to the assumption that Science is infallible somehow, or that Science is an inherent force for good as opposed to Religion, which is not...the point to illustrate is that in both, the operating factor in how each is interpreted and the benefit of each is in the delivery. And that delivery is controlled by one thing, and one thing only.....Mankind. It isn't a comparison of Science against Religion, because the two address different things in different ways, they can be both complementary or contradictory to each other, again dependent upon one thing...Mankind.
Each is a tool, they do different jobs and trying to use one tool to the job if the other is at best foolish and at worse dangerous.
How did the gastric breeding frog's reproductive system come about, evolution?
Witchcraft always has a hard time, until it becomes established and changes its name.
We hear much of the conflict between science and religion, but our conflict is with both of these. Science and religion always have agreed in opposing and suppressing the various witchcrafts. Now that religion is inglorious, one of the most fantastic of transferences of worships is that of glorifying science, as a beneficent being. It is the attributing of all that is of development, or of possible betterment to science. But no scientist has ever upheld a new idea, without bringing upon himself abuse from other scientists. Science has done its utmost to prevent whatever science has done.
I conceive of nothing, in religion, science, or philosophy, that is more than the proper thing to wear, for a while.
Sure but again with the Jigsaw analogy. If it looks like the Eiffel Tower, don't turn it into the Big Ben.
Science has gaps and each time they are getting found God doesn't seem to be hiding in any of them thus far.
How did the gastric breeding frog's reproductive system come about, evolution? The only plausible explanation is by design.
Lack of faith there Freefaller. Seems like your hanging onto it by your fingertips.
Castiel you would make a good politician sidestepping around the obvious.
Just one piece of evidence, DNA code compared with a chimp 96 percent the same.
Evolution is what happened, regardless of how it first got here. Does the bible interpret evolution in any meaningful way. Quite hard to look past it. If not then the rest of it is hogwash.
Obviously they can each be used in good and bad ways, but I'd have to say that overall science has a significantly higher good:bad ratio than religion. I feel that the millions and millions saved through medical research (to name one benefit) is more good that religion will ever do.
The fact such blatant troll posts manage to elicit continued reactions as they are doing is quite impressive I must say.
And the millions and millions killed by weapons created using the application of science, the destruction of our ecosystem using the application of science..the creations of schools, libraries, hospitals, scientific discovery itself through the application of Religion...the point I'm making is that you cannot objectively quantify the ratio of good and bad, you can only judge the application of each as it is defined at the time.
500 years ago you might have been able to glean some meaning.
1000 almost certainly not.
Well yes, it's not exactly a precise measurement of how much good and bad each has caused. But I would rather go withot religion than science; I would be surprised if many would disagree.
The point is that you needn't go without either. They do not function as an either/or choice. Like that quote LOAM offered, they are merely different suits to wear at different occasions.
Things that we know to be wrong, and no longer useful or relevant, are thrown out. Miasma theory for example.
Miasma theory was not predictively accurate when used though. That is the distinction. The examples I gave are known to be wrong in some circumstances but correct in others, or rely on assumptions within the model known to be untrue.
It is perfectly possible for a scientific model to be both wrong and useful.
