I bought the Sapphire R9 290 Tri-X OC model a couple of months ago but I started to having issues with texture stretching in WildStar (such as textures original from one central point and fanning out and warping across the screen). I sent it back for another card and when I received the new one it also did it but to less of extent. I put it down to just driver issues for a pretty new game.
After that I played these following games and I've no issues at all (literally no issues, not one sign of corruption, texture issues, crashes or bsod's etc):
Bioshock Infinite (including all the DLC)
Project Zomboid
Shadowrun Returns
A Wolf Among Us
Marvel Heroes
Civilization V
Now I've just started to play Elder Scrolls Online and after 2 days this has started to happen:
http://i.imgur.com/WFhhLlc.png
It's a perfect square on the screen that persists from in game to the login screen and back. It's blocks are made up of stuff I'm looking at, but also garbled blocks such as the bright green ones.
This is the first time I've had it. I restarted the game and it went away but I'm very concerned about the card now as that really does look like memory corruption... but I guess it could also be drivers. If I had consistent issues across multiple games then sure I'd send it back immediately even though it's the second card I've had in under a month, but it's not happening in all games.
The card is generally around 65 - 75c under load. I've ran furmark and OCCT to look for artifacts but no problems are showing. Full PC specs are:
Intel i5 2500k (stock)
Gigabyte Z68P-DS3
8GB DDR3 9-9-9-24
Sapphire R9 290 Tri-X OC 2GB
Seasonic G Series 550W Modular PSU
Could this be driver issues or is this pointing more towards a problem with the card?
Project Zomboid
Shadowrun Returns
A Wolf Among Us
Marvel Heroes
Civilization V
Gigabyte Z68P-DS3
8GB DDR3 9-9-9-24
Anything up to +100mv will be perfectly safe with that card.
