Every time I set the memory to run at 2133Mhz the system fails to boot and even at 1866-2000 the system is unstable.
I've set the voltage to 1.65V and timings to 11,11,11,31 as per the documentation.
I'm using a Gigabyte Z97X-SOC, why won't the memory run at full speed it's rated too? motherboard limitation or bad memory?
