Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM @ £5.99 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
- Super silent APACHE fans in Black Stealth colour
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 2.64 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Only £5.99 inc VAT.
ORDER NOW
_____
Aerocool Strike-X Super Pad Gaming Surface @ £10.99 inc VAT
With this Gaming Mouse Surface from the specialists Aerocool you have control over what happens on the screen, whether for work or play.
It offers a massive 880 x 330mm surface area, which is wide enough space for the keyboard strokes and mouse movements.
With the stylish eye-catching design on the front and an anti-slip coating on the back is the three-millimeter-high Aerocool Strike-X Super Pad is the ideal complement for any demanding PC users.
- Dimensions: 880 x 3 x 330 mm (W x H x D)
- Material: Natural Rubber
- Color: Black / Red / Yellow
Only £10.99 inc VAT.
ORDER NOW
- Rated voltage 12V
Only £5.99 inc VAT.
ORDER NOW
_____
ORDER NOW
