Hi guys, just looking some thoughts regarding the positioning of a sensor light at the front door.
Basically, an electrician had a look at it and gave me two options
1) He could take a wire from an existing light to the new sensor light, but this would entail running conduit across the front of the house to reach the new light, and this would obviously look a bit unsightly.
2) He could fit the sensor light level with a an upstairs bedroom floor, drill a hole through the bedroom wall and use a plug to power the light. Again, this would involve using trunking in the bedroom to enclose the cable.
Option 2 would look better as there would be no outside conduit, but I'm concerned that drilling a hole through a bedroom wall would cause an issue with damp or draughts!
Which would you go for.
