He has a small one, but now is the time to get a 500GB M.2 card if he is replacing motherboard.Do you have an SSD already?
Don't upgrade that 2500k. It's a very good CPU, you don't need to waste it. Get a used 2600k/2700k. Like a 15% performance reduction from the latest Haswell-Refresh CPU, really not worth spending the extra. You could get 2x R9 290, 450D and new PSU and a £100 2600k easily in budget
is it not worth jumping to the new CPU'S from 2500k or 2600k???
gaming wise new upcoming titles dragon age/witcher 3 etc etc
isn't my current PSU any good? im deffo getting rid of the mobo just don't like it plus want to go PCI 3.0
Right
YOUR BASKET
2 x Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card £269.99 (£539.98)
1 x EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply £139.99
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £91.99
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25
2 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99 (£29.98)
Total : £1,006.51 (includes shipping : £8.00).
Xfire 290's
New cooler with fans to overclock the poo out of your (new) 2600k
450D with two new AF140 fans
New SSD to replace your small current one
EVGA G2 PSU - made by SuperFlower, 10 year warranty, plenty of powa
+ ~£100 for a 2600k
Job done
Why change motherboard and CPU? If you want it for gaming, your best bet would be to stick in 2 x 290 or 2 x 780 cards.
If someone posts stats of say Crysis 3 1st level average FPS in 1440p with the following;
i5 2500k@ 4.6GHZ
Z97 board & i7 4790i @4.6ghz
and the 4790i is much better...then go with that. However I will edge my bets that it wont be
Waste of 2 gpus with an i5, you want an i7 with multiple gpus. However yes, I wouldn't waste the mobo etc, sell on the 2500k and buy up a 2600/2700k
1920 x 1080, max details, max AA, max AF fps Index
Core i7-4770K Stock 54.2 100.00 %
Core i7-4770K 4.5G 54.0 99.63 %
Core i5-4670K Stock 54.3 100.18 %
Core i5-4670K 4.5G 54.3 100.18 %
Core i7-4770K Stock 21.2 100.00 %
Core i7-4770K 4.5G 21.8 102.83 %
Core i5-4670K Stock 21.6 101.89 %
Core i5-4670K 4.5G 21.4 100.94 %
