Yeah, you will need to double the wraps at least to get it to fire on a Vamo. Certainly over 1 ohm but probably 1.2 - 1.3 would be better.
Or spend £20 on a half decent mech mod and get that coil working to its full potential.
Any recommendations?
: http://www.1stopmodshop.co.uk/index.php/mech/nemesis/48-nemesisHa ha. Nah, you can vape whatever you want, it's fine. I just find better flavour when I'm getting more power through the thing (well volts really).
For example, my kayfun is currently rocking a 1.3 ohm build, and I'm vaping between 12-15 watts. So this is between 4 - 4.3 volts. I just find this is the sweet spot for this build. But if you prefer your vape at 10 watts, then that's fine.
For reference though, your 0.6 ohm build, on a mech with a freshly charged battery, will be kicking out over 35 watts at 4.2 volts. Which is beautiful in a dripper. But I doubt it would actually feel like too much if you were to try it either. Your battery would be LONG past it's best (read: recharging point) to get down to 10 watts on a mech.
So, in my, albeit limited experience, I would suggest a higher resistance build. My Kayfun was pants with a 0.5 ohm build in it, and REALLY came alive with a 1.3 ohm build. My Fogger rocks a 1.3 Ohm build also. I prefer builds around 1 - 1.4 ohms in tanks, and lower in drippers on mechs.
My lowest dripper was at 0.15 ohm, which is 117 watts. And it was sick as ****...
I saw a 400W build somewhere (possibly this thread) a while back which was essentially a bunch of stacked batteries, looked crazy!
You can. If you're confident it wont short. But it is better being safe when dealing with potentially explosive batteries.
Yeah, you don't need to sub ohm. 8-10 wraps of 0.3 kanthal wire microcoiled should keep you above 1 ohm fairly easily. I can't actually remember the wraps in my KFL just now.
You can use thinner wire to increase the resistance, or thicker wire to decrease resistance. And when you get more confident, you can try different coils, like twisted or parallel to reduce resistance in thinner wire. I have a dual coil build with twisted 0.5 wire in my Tobh knocking out 0.17 Ohm. That's wildly sub ohm though.
So just a V1 then? Not V2, 2.5 or v3? Are they 22mm or 23mm?
SX chip would be what you want for proper regulated sub-ohming. The DNA is fine, but at it's lowest resistance build it will fire, at it's highest wattage, it's still only firing 3.87 volts, so in a mech, your battery would be more than halfway dead. If you get what I mean.
At least the SX can hit 50w (the v3 330 chip is now doing 100w), or you can bypass the circuit, although you are still limited to the 0.2 ohm coil by the safety circuit.
Thanks for the info, this is gonna get expensive
Can you just build a standard coil for just a normal vape to begin with?
Reason I ask is I'm new to this so wanna start off slow and learn all the sub ohm stuff as I go. Haven't got a clue at the moment but I pick up stuff like this pretty easy.
Why can't use put a coil without testing (rough guesstimate) will it blown up or something lol.
Edit: forgot to ask, can you not just use any charger? I got one for my mouse batteries.
