Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail @ £233.99 inc VAT
Want to tune every aspect of your system for the ultimate in total system control. Then the new unlocked Intel Core processors which enable system tuning for the processor cores, memory, graphics, and power, were made for you. Whether you are a novice overclocker or a seasoned veteran, these processors will have you singing their praises in no time.
Looking for the perfect processor to build your gaming rig around? But you also want to edit your action videos and photos? But to do this you know you need serious performance. Not to worry - Intel is happy to announce our first 4GHz base frequency quad core processor. If it is performance you crave, then this is the processor you have been waiting for. But what if you feel the need to overclock your system to squeeze every last bit of performance out of it? Well, then this is still the perfect processor you. The lastest 4th gen Intel Core i5 and Intel Core i7 processors, paired with the latest Intel 9 Series H and Z chipsets, will get you the results you want. Add in features like built in visuals and Intel Quick Sync Video, which allows the conversion of media from one device to another and prepares your media from one device to another and prepares your media to share online at incredible speeds, and these are processors that meet every need you have.
The Intel Core processor family delivers a great PC experience. Whether you are looking for improved performance, greater adaptability, or differentiated visual features, Intel has the processor to fit your needs. Whether you use your PC for creativity, playing games, or everyday task such as homeworkd and email, these new processors make it easier to design, render, edit, play, and share.
Intel Core and for Intel Core i7 processors, Intel Hype-Threading Technology allows each processor core to work on two task at the same time, improving multitasking, speeding up the workflow, and accomplishing more in less time.
With 4th gen Intel Core processors, you can boot your PC, load applications, and resume from sleep nearly instantaneously thanks to Intel's responsiveness technologies such as Intel Smart Response Technology and Intel Rapid Start Technology.
The 4th gen Intel Core processor family offers hardware-level security that helps protect your devices, your data, and your online transactions.
The 4th gen Intel Core processor family automatically connects to wireless hotspots. Your email, social media, and apps are always updated thanks to Intel Smart Connect Technology. Finally, wirelessly stream your HD / 3D video and games to your TV or projector for presentations and entertainment using Intel Wireless Display Technology.
Features:-
- Improved thermal interface material (TIM)
- Updated packaging materials
- Supported by new Intel 9 series chipset
- Re-engineered for Enhanced Performance & Overclocking
Specification:-
- Lithography Process: 22 nm
- Cores: 4
- Threads: 8
- Frequency: 4.00 GHz (Turbo Mode 4.40GHz)
- Integrated HD 4600 Graphics
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
- Socket: LGA1150
- Memory compatibility: All DDR3 1333MHz and above is compatible
- PSU compatibility: Check out our range of Haswell compatible PSU's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 3yr Warranty
Only £233.99 inc VAT.
ORDER NOW
________
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £749.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Only £749.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Cores: 4
- Threads: 8
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
________
Specification:-
- Panel Type: IPS
- Warranty: 2yr
ORDER NOW
Anyway, that's a decent price!
