few upgrades for friend £100 tops
8 Aug 2013
Stoke-On-Trent
He really needs a sdd, fans(stock corsair ones are to loud) and a new keyboard hes currently got a cheap zalman keyboard his budget is £100 as hes only on a apprenticeship atm
i came up with this but no doubt you will have a better idea on what he could get for that money :D
YOUR BASKET
1 x SanDisk Ultra Plus 128GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDHP-128G-G25) £46.98
1 x Corsair Raptor K30 Gaming Keyboard (CH-9000043-UK) £37.99
2 x Antec TrueQuiet Pro™ 120 Revolutionary Quiet Cooling 120mm Case Fan £3.98 (£7.96)
Total : £92.94 (includes shipping : ).
What does he have currently in therms of a full system? Spending 45% of your upgrade budget on some fans and a keyboard seems a waste.
fx 8320
corsair 750w
Gigabyte 990 fxa
corsair h100
8gb ram (cant remember which it is though)
Edit: knew i missed something hes had my gigabyte windforce 280x as ive jsut brought the xfx 280x
could you recommend any other fans as ive read its static pressure you need for cooling using radiators ive just seen the zaward oem golf fans that have a SP of 3.48mmH20 where as the spectre only have 1.64mmH20 of pressure so wouldnt the golf fans be better at cooling using the h100? or am i looking at this wrong?
Ah they are for the H100, didn't know. Tbh I have no idea about static pressure fans apart from the SP120's are good but about £10 over your budget for a pair... That 3.48 of the golf fans is higher than the quiet edition SP120s! :o
