The next decent step from 6950's in Crossfire?
10 Dec 2004
Oxfordshire
So,
Having just bought a new CPU, water cooler, new fans etc for my system
I am now thinking that some new cards might be nice in the near future.
for a budget of 150-200 (MM of course) what do you reckon I got get...if anything that that would be a decent jump from the 6950's?
My initial thoughts were 7950's or a pair of 280X's might squeeze into the budget, but would they be a big improvement apart from the fact they will do mantle
Maybe i will just play the waiting game on a used 290 then :). However i think at the right price a 7990 could be a tempting option
Thanks for all the info guys, massively appreciated
if you aren't in any hurry to upgrade, I would wait until September October before making a decision. You have held onto the 6950's this long, a couple more months won't hurt.
New cards are on the way from both companies and it's looking very likely that both NVidia and AMD will release cards between now and the end of October. That would mean there should be some good second hand cards for great prices popping up on the MM.
Done the unlock, unfortunately only one goes to 6970 :(. They are PE Cards do are quick for what they are anyways
290 is looking more and more tempting. Seriously quick card! One on MM for £190 now!!
I seriously need 1000 posts thats incredible value for money
6950 cf is equivalent performance wise to a single 7970/280x, agree you should sniff out a 290, seen ref ones go as low as £180-220, bargain, or find a little more cash and grab one of those aib cooled 290's for £270.
Due to the price of the 290 cards atm, thats where I'd put my money. Very nice upgrade in performance that uses less power too. Plus then you have the upgrade option of adding another later down the line if you require it.
