that's one way of doing it!
so i'm assuming your plan to put 120.1 x2 on the mobo side, 120.2 and 140.1 on the psu side?
Are you going to add any mass storage? (As it being a NAS and all)![]()
How does the Node 804 'feel' in terms of real life dimensions? I've only ever seen pictures, and they make it look a bit large. I wondered whether the depth/width actually made it seem that big or if it was relatively small, if you catch my drift....
By measurement it is near enough the same size as the Lian Li mATX cube I recently built (maybe 2cm wide and taller).. but it does "feel" bigger inside certainly I think the middle split gives it the feel of a larger case because you have the rear room for extra stuff..
I think the styling also makes it look bigger.. think if it like an EVO compared to a normal hatch back.. with the wheel arches and beefy body kit it looks bigger but in reality is the same sort of size as a Mondeo!
In terms of actual usable space inside.. its an mATX case so you need to be a bit careful.. I had to be careful in radiator choice for-instance as a lot of 120.2 radiators are too large.. also once I get the radiators in and the res/pump as well you will see that actually its all very tight.. maybe 2 - 3 cm clearance between parts.. one of the reasons I have chosen to work with hard-line this time is that with normal tubing you have some very tight turns and bends.. and to get it nice I could have spent £150 on fittings easily.
I see, that's interesting. Sounds like it fits your needs pretty much perfectly anyhow. I think it's good to use a case that is as small as possible whilst fitting your required hardware, personally. Perhaps a banana for scale pic at some point in the build log?![]()
probably not a banana but certainly I can take something to show scale! I think once you see the GPUs in you will realise how small it is. lol.. I'll look into thatprobably not a banana but certainly I can take something to show scale! I think once you see the GPUs in you will realise how small it is.
I went through a stage of huge cases but I just don't have the room in the man-cave for 3 / 4 massive PCs!
Yeah, there's something impressive and imposing about a ridiculously large PC... But they're almost always completely unnecessary! The Chelsea tractors of the desktop.
Looking good so far, very interested to see how this evolves. I was seriously considering this case as an option but went with the Air 540 instead.
Where did you learn/practice your water cooling skills...thinking about it myself at some point but nervous about making the jump...so starting with a CLC to begin with.
Will reference your build to see how you get on and see what I can learn.
Good luck and enjoy
Didn't expect that to be the reservoir mount spot!![]()
