need some peopless opinions..
27 Oct 2013
hey guys im re overclocking my CPU i74770k from stock to 4.4ghz with a new cooler (corsair h100i) i used before (Prolimatech Black Megahalems CPU air cooler) and was hitting around 80c playing BF4 so would i see a dramatic difference using h100i over Prolimatech Black Megahalems CPU air cooler or is the overclock too high?
should i reduce the overclock then if my cpu is reaching 80c in bf4?
See if you can turn the Vcore down a bit to reduce temps therefore noise. Secondly if that doesn't work then try to reseat the cooler using decent thermal paste.
